Weil Mclain noise.
nicky1283
nicky1283 Member Posts: 5
My brand new boiler is making the same noise as in this video anyone know the fix
https://www.youtube.com/watch?v=dstGyZThNqk
  • nicky1283
    BTW it a weil mcleain
  • Gordy
    Gordy Member Posts: 9,546
    No codes?
  • rick in Alaska
    rick in Alaska Member Posts: 1,505
    I would open it up and look inside the fan inlet. Sure sounds like something is stuck inside it and rubbing on the fan blades.
    Rick
    Gordyjonny88
  • Gordy
    Agree with @rick in Alaska . Do it before the fan is toast.
  • JohnNY
    JohnNY Member Posts: 3,333
    It can only be the inducer (fan). Probably a problem with how the casing is secured.
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
  • nicky1283
    Thanks all for the feed back. We just opened it up and checked the fan. Any other suggestions.
    This tends to happen in Zone 3 and Zone 4 after we turn the heat up it does not happen all the time. Right after the noise stops I hear water circulating in the system.
    Could it be not enough water getting to machine or gas?
    Thanks again !
  • Gordy
    What is the system psi gauge reading?
  • nicky1283
    from 12 - 15
  • kcopp
    kcopp Member Posts: 4,606
    Bump it up to 18
  • Danscrew
    Danscrew Member Posts: 130
    Put your hand over the fan inlet slightly to see if it the noise changes any its either the fan or pump flow
  • nicky1283
    Thanks all for the feedback. I reached out to Weil Mclain's Tech support today and they asked if our exhaust run was long or short. We told him 4 ft - he stated that was short & we are getting to much air to the boiler. We were told to put in part # 383700235 to stop the noise
    This info is not in the manual just came up recently and no charge for part. You must reach out to distributor
    kcopp
  • rick in Alaska
    I doubt that is the problem, but weirder things have happened. Sure sounds like mechanical noise.
    Hope it fixes the problem though.
    Rick
