Cleaning and Repairing Vents
randallkc
Member Posts: 38
I am in the process of getting a one pipe steam system back up and running that has been shutdown for about 5 years. The old boiler is being replaced and I expect to have problems with radiator vents and valves. I plan to repack all the valves.
What is the best way to clean the vents? I have a ultra sonic cleaner. I was thinking of using vinegar and putting them through a 10 minute cycle? Most of the radiators on this system have Danfoss Thermostatic Valves and Hoffman 40 vents.
I have boiled my 1-a vents in vinegar , the results were " meh ". Time would be better spent on the main vents , I just boiled a couple of Gorton 2's last week , lol. It seemed to help freshen those up a bit .hvacfreak
Mechanical Enthusiast
Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV'sEasyio FG20 Controller
I've used CLR on radiator vents with good results.0
I have some CLR. I may try that. I basically purchased a new box of vents as well as a new main vent. However I will also need them on another system too.
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
