Boiler selection
j a_2
Member Posts: 1,801
Early 1900 era home in South Boston, wants existing heating system entirely removed, it's just a maze of pipes carrying heat every way possible,via mostly copper fin baseboard...it's a mess...Existing 30 year old gas boiler on its last leg...The home is vintage and well taken care of...Wants to install runtel type radiant panels in each room, via a heat loss,of course..going with 4 zones,the home is approx,3k sq.feet...Main dining room has in floor old indirect duct, that now has c/I emitters in it, wants to replace with similar..
that's what he wants....What's some of your thoughts on boiler and equipment...The owners like the European style. there will be a couple of micro zones....No in floor radiant, he doesn't want it..Job starting soooon..Thanks guys..
Personally I like IBC SL160 has some great features.If there is going to be micro zones ask Rich about HTP as you can eliminate the need for buffer tank.Sounds like a nice job.0
I know but I will, but your inputs are always welcome0
As Kurt always suggest, look at the turndown rate and how it matches up with the smallest zone load, you may not need a buffer tank.
I like the features on the Lochinvar controls, it allows you to really fine tune the boiler to the job. The ramp delay can really help eliminate short cycles also, just program in the steps and limits. with the Con X Us system you can watch and adjust that from your tablet.Bob "hot rod" Rohr
Very helpful, already learning even @ 63/yrs0
JA ,
What is the total load of the house at design , how many zones will this be ? Can you explain a bit more about the dining room floor , sounds like a hypocaust system ? will this new system be performing the DHW production also ?You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
Rich I will follow up as it progresses...Yes wanting to install 70 gallon indirect. Thank u. Sir0
70 gallons is kinda big considering how things are done nowadays . How many baths Ja ? Mention storing at 140* and using a mixing valve . Have not seen a home in quite awhile that couldn't be well handled with a 45 - 60 gallon tank .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Actually correct 60 gallon. I do listen!!!I send you a p m with some details0
The Viessmann B2HA-19 modulates from 12k to 67k. Nice unit.0
HTP UFT 80 . 8k to80k . No P & S required (dependent) on loadYou didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Thank you for the great advise.. Homework tonight.0
Can you post a pic I am looking forward to using one.How did you find installation etc.
The best way to address short cycling without a buffer tank is the new US boiler Sage 2.2 control and their new zone panel. De-rate the boiler rpm's to match load for heating and hot water independently, increase or decrease the fan PID on display, adjust low fire hold time, reduce light-off rate, differential above setpoint temp, and add the new zone control panel that allows you to program each zone and it limits the boiler input to meet the loss of the zone.1
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
