Weil McLain 97+ boiler: PP or CPVC?
Matt Wynne
Member Posts: 8
Hi:
I'm installing the above system in my house. I would like to vent with polypropylene, but the manual states that 1st pipe connection to the boiler must be CPVC, which has a lower max temp.
I called them asking about this and they said it was because the engineers tested the system with CPVC.
Since I would like to run this rig with a return temp that would approach the max temp for CPVC, I would feel better venting it with PP. So, PP makes better sense and is safer, but I would risk voiding of warranty.
Any thoughts?
Any thoughts?
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
