What have I got here?
BillE
BillE Member Posts: 3
can anyone identify this? My house was built in 1921. This is in the basement.
  • JStar
    JStar Member Posts: 2,752
    edited July 2015
    That is a very old steam boiler that use to operate on coal. Do you still have steam in the house?
  • BillE
    No steam in the house. I have tried to google this boiler to get more info about it but have not had any luck. As you can see, there are parts missing and I can't find any model information. Do you know where I could find information on this? We find it interesting and I would like to know more about it. Thank you for responding.
  • JStar
    Is there a name on it? Looks like something is cast into the upper left side.
  • BillE
    The only "name" I could find on it is Arco. The was on the top right steam regulator. I was googling that when I came across this site. The markings on the top left is steam PSI.
  • JUGHNE
    JUGHNE Member Posts: 11,042
    I think that ChrisJ should restore it , it would really compliment his Fridge, about the same size. :)
    Steamhead Member Posts: 16,796
    Probably was originally and some idiot tore it out.
    Consulting
    RobG
  • 4Johnpipe
    4Johnpipe Member Posts: 480
    The name was probably on the lower ash door that is missing. What is stamped inside the hinge on the lower right?
    LANGAN'S PLUMBING & HEATING LLC
    Considerate People, Considerate Service, Consider It Done!
    732-751-1560
    email: langansph@yahoo.com
    www.langansplumbing.com
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,576
    You may find more information here if you look in the library for ARCO, (American radiator company).
    It looks to have some of the draft regulator counterweight linkage, and the pressure relief valve on it. Could be from 1890.
    At some point, possibly due to a lack of steam knowledge, a contractor removed it and the system it supplied.
    You could have been enjoying very quiet, even, and economical heat, had it not been for that fellow!--NBC
  • ChrisJ
    ChrisJ Member Posts: 15,588
    edited July 2015
    But boilers? No thanks.
    Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment
    JUGHNE
  • JStar
    I would fix it up and use it to destroy evidence.
    CanuckerRobG
  • RobG
    RobG Member Posts: 1,850
    I would clean it up, paint it and use it as a patio fireplace.
