How NOT to do a Staple-Up application
Paul Pollets
Member Posts: 3,656
The pic shows how a staple-up application (in a crawlspace) without plates was installed. One 1/2" pex pipe fastened to the side of the TJI. This work was done in a $3mil home. The second hole was popped or drilled, but the return of the Pex loop was left out. It runs down the adjacent bay. To lack the skills to install the work properly is nothing that unusual, but this one takes the cake. The plates that show were just installed by us as we retrofit the home properly. Learn your craft!!
Wow! How come the joist spaces aren't ever that clean when we put up plates???Steve Minnich0
So as a homeowner I am curious. Do these people go back against the original installer for it being completely improper? Should they be entitled to some money back from this installer? I hear these stories and see the garbage work and it really gets me curious what recourse I would have as a homeowner. Obviously getting a good contractor should be a first step, but in a situation like you are fixing what happens? Does the homeowner just eat it?0
I think the biggest thing I have learned from this site, if I need HVAC work done come here and only hire someone from this site. Well it will be right once you are finished. After 10 years yeah they are going to eat it. Thanks for the response.0
I walked into an 8 million dollar home a couple weeks ago. A Ranni on demand was powering the radiant system. Right beside was a manoblock that was the ugliest looking thing I ever did see. Not a single pipe was supported prior to entering the joist spaces above. #Spiderweb.
@Paul gotta be some sneaky satisfaction in being able to come back 10 years later and show him your stuff.0 -
There is a hydronics god. Justice has been served. Here's a pic of the boiler room. Of course the contractor who made this mess went out of business several years ago.0
Beautiful work.I know we dont discuss pricing but I cant imagine.Pity it wasnt done like that the first time.Fostapex is nice to work with .I used it on a job ,good material.I see you crimp does it pay in the long run,i am still on the fence.Thanks for sharing.0
Thx, Johnny88. We squeeze most of the fittings, still thread black pipe. I converted to press fittings in 2003 and never looked back. It saves a lot of time and eliminates the leak factor.0
That 'staple up' is run of the mil work around my parts. It's disgusting. You cannot even buy transfer plates at one suppler, they're special order because nobody buys them. Its sickening actually.0
Paul,
I have to admit when I first looked at the pic of the plates I thought to myself, ah crap whats wrong with that, thats how I do them. Then I saw the lower tubing and felt much better. You are alone, on the rough clients, heres one a friend wanted me to inspect. I had to deliver the bad news of not only can't I inspect but I need to shut it down.Tom
Montpelier Vt0 -
I like to say. Do it once do it right. Do it cheap and hope you saved enough to do it again.
Running potable off the heating system?0
It had a solar potable system with indirect backup. It was closed loop on the heating side.0
Didn't there used to be a "Wall of Shame" thread or folder?0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
