Radiant Fix near Seattle
Paul Pollets
Member Posts: 3,656
This is one of the hardest retrofits/repairs I've had to deal with. The incompetence of the original installer was stellar. As we finished the rooftop venting for the new Vitodens, we discovered the solar array heat tubes were put in backwards, with solar side facing to roof rather than the sun. Can't fix stupid, but the new system is what should have been done 10 years ago. Funny that I bid this job 10 years ago.
3
Nice to see the finished product -- and a nice one at that. I smell a happy customer.0
I wonder if the customer will know about the improvements, as he was unaware of the reversed solar panels, for 10 years!--NBC0
Great job, Paul.Steve Minnich0
What type of wire did you install for the line voltage. Mine always ends up looking like a rats nest.0
Nice save, good for you, the customer and the industry.
Sometimes those evac tubes get turned to limit or prevent overheating on low load, or oversized arrays in the summer. Then turned back in the winter.Bob "hot rod" Rohr
HR, this system was never serviced nor had glycol.
Bricksea, we used SOFA wire for the mixing valve motors and pumps.0
Thanks, I have been using ac and it seems to just go where it wants to go. Your job looks nice and neat.0
What is SOFA wire? I did a search and came up with couch repair parts.0
Please post pictures of the upside panels...That is a first in my book!!!!LANGAN'S PLUMBING & HEATING LLC
Considerate People, Considerate Service, Consider It Done!
732-751-1560
email: langansph@yahoo.com
www.langansplumbing.com0 -
Sweet job by the way! Pretty work!LANGAN'S PLUMBING & HEATING LLC
732-751-1560
I think this is worthy of an article. All of our magazines show the best of the best, when in reality, people need to see what happens of they don't do due diligence. I'd bet he paid more the second time around than he did the first time around, and then there's the pain and suffering... Being able to sleep at night knowing you will wake up to copious amounts of DHW is... Priceless! Great job as usual Paul. Deadline is next Friday :-)It's not so much a case of "You got what you paid for", as it is a matter of "You DIDN'T get what you DIDN'T pay for, and you're NOT going to get what you thought you were in the way of comfort". Borrowed from Heatboy.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
