What is this?
RayWohlfarth
Member Posts: 1,481
I just visited an old building with a steam system that is about 100 years old. I saw this valve and would love to know what it is called. The radiator has this on the inlet as well as as a trap on the outlet. It is a downfeed system. Thanks
This is what I love about this industry. No matter how much you know, it has a way of humbling you.
Ray Wohlfarth
Boiler Lessons
Boiler Lessons
1
It's a Webster double service valve used specifically for downfeed systems. It's a combo trap and supply valve.0
My mentor experimented to economize installing steam heating in multi-storey buildings.He once tried separate supply and return connections to single pipe down feed.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
