Sorbox water filter for Hydronics
Paul Pollets
Member Posts: 3,656
Installed the Sorbox filter yesterday at a facility using 8 Viessmann boilers to heat every building with radiant floor heating. If the Sorbox works as it should, it will eliminate the need (and cost) for any boiler water treatment chemicals. The unit requires a 3-valve bypass for installation. The first building is a 24 room dorm with a Vitodens 200 mod-con as the heat source.
1
nice installation. doesn't the Sorbox have valves built into it to eliminate the two additional valves you added?Bob "hot rod" Rohr
It does...but we used additional valves just in case.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
