Emerson swan
Snowmelt
Member Posts: 1,457
Did I hear right,did emerson swan drop ao smith.
It's not like I'm against ao smith but they did me wrong.
They ask me if I wanted to be one of there service contractors I done it for about two years, they send a letter and drop me. Every unit I went out to fix I did or I replaced. I even did a few where the customer gave up and I was last resort.
I have the main guys number and name on my white board from ao smith, he never returned my calls, with that being said, aosmith top dogs are full of themselves I kinda give up on them as a family. To me a water heater is a water heater all it does it heat water.
Oops I was getting carried away, the original question is did emerson swan drop a. o smith?
Emerson Swan
They did in fact dump AO Smith recently . They also became the rep for HTP and HTP got rid of Gooding as their rep . Sounds like both companies did a lot of thinking about where the future will bring them .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
Water Heaters.
Because of the new 2015 water heater Reg's, HTP is on the cutting edge of high efficiency water heaters. Emerson-Swan isn't going to be found short for water heaters.
http://www.htproducts.com/phoenixldwaterheater.html0 -
Doesn't AO Smith
own Lochinvar? I suspect you will see some really cutting edge tanks and boilers from them also. You already do, actually.Bob "hot rod" Rohr
Lochinvar:
Who Reps Lochinvar? I'll bet that whomever Reps Lochinvar will be the new distributor for AO Smith.0 -
AO Smith Rep.
Maybe FIA.
They rep Lochinvar.0 -
I think AO Smith owns the world, don't they?
Or at least it seems like they do.
ME0
