How to loop 2 cast iron rads
jonny88
Member Posts: 1,139
HI all.Customer lives in an old georgian house .House is 3 stories and is on one zone,a large gravity system.On the top floor there is a bathroom with a cast iron rad.In the bedroom 6 ft away is another cast iron rad.The bedroom radiator has a seperate feed and return coming from basement.At some stage the riser to this rad was disconnected.The bathroom rad works fine.Im assuming there was a leak or some issue with the bedroom rad.Heres my ?.Can i make a loop with the bathroom rad and bedroom rad.I was looking at systems etc on the site and can't find a drawing that shows the correct way as I am figuring air will be a problem.Thanks in advance for any input.
Loopy rads:
If you "Series Loop" two radiators together, the first radiator has to fill with hot water before the second radiator fills. Experience shows that the second radiator never works properly.0 -
Still Gravity?
I agree with Ice that it probably won't work well, particularly if it's still gravity. If it's been converted to forced flow, you make it workable by adding a small circ on that riser, but the first rad will still heat up first.Bob Boan
thanks guys for your info
i am actually going to install a manifold and run a homerun to each rad. Thanks for the advice.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
