Watts
Bob Gagnon plumbing and heating
Member Posts: 1,361
Needs a proofreader.
Thanks, Bob Gagnon
Thanks, Bob Gagnon
Edit
Otherwise, that would be a pretty boring display.0 -
You can' read it
Easily. But it says "cut no dashed lines for display" it should read "cut ON dashed lines for display"To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Proofread:
When English isn't even a second or third language of the country of manufacturer, things like this happen.
Its like reading the instruction manual and knowing that the written syntax isn't like any you've ever read or spoken before.
Globalization.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
