Extend a zone from a kickboard heater?
Ranman
Member Posts: 3
I am adding on to my house and one of the new rooms will be a walk in closet for the master bedroom on the 2nd floor. My existing house has four zones. There are two zones on the second floor of the existing house, one that feeds three bedrooms and one that feeds a kickboard heater in a bathroom. The kickboard heater zone rarely comes on, because the bath seems to get heat flowing in from elsewhere. I can heat the closet by extending loop going through the bedrooms and putting it on that zone, but ideally it would be good to have it controlled by its own thermostat. I was wondering if there is a way to do this using the loop that goes to the kickboard heater, since that zone is under utilized and the piping is not too far away from the new closet?
Yep
That's the answer. Do you want to abandon the bathroom kick board header.?
What does your boiler room look like do you have a picture of that.0 -
More info
I don't want to abandon the kickboard heater in the bath. Here is a pic of the boiler room focusing on the zoning pumps.0 -
How's your chance
Up date the near boiler piping.
Bumble bee pump, centre zone valves
Out door reset.
Pump away from expansion tank.
Do all that I can guess you will save 20% or more on gas bill.
Or
You want to install another pump and creat another zone. Really not that difficult.0 -
Is there a device that can bypass flow to the kickboard?
I am wondering if there is a device that I can installl behind a wall somewhere on the second floor that will divide the flow and bypass the kickboard when it is not calling for heat. Is there such a device and if so how would the design of such a system look like?0 -
You don't
Want to put anything behind the wall, what would be the big deal if you just made another zone?
Pink cheap way of doing this.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
