Balancing Valves
heatingFun
Member Posts: 84
I <a href="http://blog.jacksonsystems.com/two-pipe-return-systems-direct-vs-reverse/">read online</a> and some says the balancing valves are needed for two pipes system, even for reverse return setting.
Do you real use them in reverse return? how do I know if I need them? where should I install them?
<span style="color:#000000">
</span>
</span>
Balancing valves
Are useful no matter what the piping topology. In a properly configured reverse return design (which includes properly sized emitters) they will need less adjustment, and can usually be specified as simple balancing valves rather than the (more expensive and complex) pressure compensated type.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
