Does anyone know...
Tinman
Member Posts: 2,808
If Uponor's Multi-Cor fittings will work on the old Ipex Warm-Rite pex-al-pex? I have some 3/4" I have to cut into and move around and I want to make sure I have suitable fittings on hand before doing so. Thanks.
Steve Minnich
Answer
Found the answer I was looking for...thanks.Steve Minnich0 -
Not sure, but...
Roth's fittings work fine.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
