High rise hydronic heating and chilled water piping supports
dfru
Member Posts: 27
Are there any published standards or guidelines which discuss methods for supporting and anchoring vertical pipe risers in high-rise buildings to allow for expansion and contraction in the piping systems?
Any assistance would be most appreciated.
Whats the nature of the job
try this...http://www.engineeringtoolbox.com/. Many mfg have engineering guides such Anvil, Grinnell, etc0 -
Any code book
should have guidelines. Out here, we follow IAPMO.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
