High Efficiency Gas Furnace
jamesrodan
Member Posts: 1
This furnace support duel fuel system can be combined with an electric heat pump to enhance comfort and fuel efficiency by alternating between electric and gas heat, optimizing energy use and minimizing heating costs. It has energy saving motor with furnace AFUE rating up to 95%. It’s a two stage high efficiency furnace offer two levels of home heating for warm and cozy indoor are quality.........................
<a href="http://www.cleanairheat.ca/lennox-g61-gas-furnace.php">http://www.cleanairheat.ca/lennox-g61-gas-furnace.php</a>
Yeah i have gone through their given link and then i came to know that this is the best heating and cooling applainces company offering services at reasonable cost and hereafter based on professional technicians with complete satisfaction work.0 -
Yeah this is great its amazing information Ian glad this was nice information0 -
This is an AD!!!!
Yeah,
This is an ad. The posters are fake.
Watch it get deleted"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
I have had problems
with Surelite control boards from White Rodgers.0 -
No Advertisements!
Apparently you can't read or have chosen to ignore the rules of this site.
The installation in your pic is also in violation of the mechanical code: you can't pull return air from the same space where there's an atmospherically vent appliance, namely the water heater.Bob Boan
We have installed two of these units
and both had to be removed because of high CO and faulty exchangers. Company did not want to pay replacement cost.
Stay away from these units at all cost!0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
