Something New
Ironman
Member Posts: 7,367
I've often said that hardly a week goes by that I don't see something in this trade that I hadn't before. Yesterday, I had a call from a customer where their hunting riffle accidentally discharged while cleaning it and went through the boiler room wall. No one was hurt, thank God, but the Taco panel did get wounded. See the pics.
Bob Boan
You left out one detail: Does the Taco panel still work? If it does, what a neat product endorsement!
Looks as though there should be a grommet or something there where the low voltage end switch control wire goes out to wherever it goes. And the wire needs to be replaced.0 -
Actually it's sick
Here is yet another horrible example of how people trivialize guns.0 -
Still Works
I did some doctoring and it's working fine.Bob Boan
Please...
It's the desire of the owner of this site that politics be left out. Nobody's trivializing anything - neither guns or the people that pull their triggers.Bob Boan
Astonishing
I can't believe the frequency of people NOT removing the magazine, and checking the action, before cleaning any gun. This is all too common, especially amongst law enforcement personnel.
I guess it's like people NOT servicing their boilers.0 -
Pretty Much
how it goes with vehicles, but we still give drivers licenses to teenagers, it's all about responsibility. Besides it was only a switching relay and it didn't even get hurt!0 -
Gunshot
I'm surprised the bullet wasn't aimed at the 007. Maybe if it was shot from a golden gun?0 -
He Shot
the sheriff (SR) but he didn't shoot the deputy (007).0 -
Back when
I was a tech down at Ft Benning in the sixties, we got a call that an amplifier was out at one of the ranges. I put a spare in the truck and took a drive out to the range.
When I got out there i climbed up the ladder to the range control tower to look at the amplifier. When I pulled it off the shelf I found a bullet hole in the shelf and a 7.62MM shell lodged in the power transformer. The range control offices (SFC) was somewhat upset when I showed him the amp because it happened as he was climbing the ladder to the tower, all he knew was that the amp stopped working while he was climbing the tower. The tower was behind the line of fire so it was kind of interesting that a bullet ended up there.
I've always assumed any gun I handle is loaded and that there might be a shell in the chamber.
3PSI gauge0 -
No 007
No 007 on this job. Maybe the SR was the closest thing.Bob Boan
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
