Will it work?
hairball
Member Posts: 19
Will one of the wall unit condensing boilers work with cast iron radiators?
You betcha...
If it is piped to specs. Furthermore it is a match made in heaven.0 -
Radiators and new boiler
It's a perfect combination of high mass radiators, and a modern condensing boiler. However, the cheaper look-a likes from the big box store may only be water-heaters, which will not work as boilers.--NBC0 -
Thanks
Who makes the better condensing boilers?0 -
one more thing for now
Some of the boilers I am looking at rated by input. How will I now what the output is. Right now I have a gas conversion burner that set up with 100,000 input would the condensing burner be about the same.0 -
Heat loss
The only way to correctly size a boiler is to do a heat loss calc.
The output is the input derated by efficiency.
A 100,000 BTU boiler that is 90% efficient would have an output of 90,000 BTU at sea level.
Lochinvar,Triangle tube and Viesmann are some good choices.
Albert Einstein0 -
thanks
Thanks for the help everyone.
Chris0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 879 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
