Too much to list
gcp13
Member Posts: 122
Not sure what they were thinking
I don't know where to start
2 in header?
Bullheaded tee,no swing joint
16 in. A Dimension
Level mains and back pitched drip returns
Main air vents 27" above waterline, above boiler
Plugged pigtail & 3/4 90 for presuretrol
Hartford loop close nipple 2 " above waterline
Auto feeder wired wrong not working
2 in header?
16 in. A Dimension
boiler
Looks like that boiler should be in a pit.0 -
Steam
This is why drop-headers were invented. But, then again, knuckleheads think a dropped header is just a way to get a bruised toe.0 -
drop header
A drop header wouldnt work there, He said there is 16 in of a dimention. It needs to be in a pit or needs a condesate pump.0 -
Header and pump
In my opinion it needs a drop header and a condensate pump.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
Hartford Loop?
It looks like a completely dry return to me. Probably not a good idea with that A dimension. It probably calls for water mid-cycle, so add "fluctuating water line" to the list of troubles.
I'm not sure how you measured that A dimension. Is that from the max water line to the header? If there's more than 28" from the water line to the main a drop header should work.Just another DIYer | King of Prussia, PA
A dimension
I measured A dimension from where the
Feeder satisfies the lwco.
At that point it was 2 in below Hartford loop
Close nipple
It was a toss up weather to raise up above
Close nipple or get as much distance as possible.
I would like to pipe the drip down into a wet return and then back to the boiler
Customer doesn't want to do any work yet ???0 -
Bad install
What were the symptoms which led to the service call?--NBC0 -
Check heat
Check heat for the season0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
