Viessmann question
osteocruncher
Member Posts: 1
Hello,
I have recently had a complete viessmann system installed for heating and hot water.
Vitcrossal 300
Vitocell 100
vitotriol 300 thermostat
during summer i select only dhw setting and turn off the heating but my radiators are still roasting hot. I have set the hot water to be recharged between set times during the day but my heating comes on at the same time.
Any solutions?
Vitcrossal 300
Vitocell 100
Any solutions?
Vitocrossal?
Residential? Very serious house,if so! Are heat pumps running?To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
vitocrossal
yes, the heat pump is running and is set on auto.0 -
New?
Is this a new install or an older unit that worked normally prior to this? The heat pump will not run when above WWSD,are you sure it's running or is it gravity flow through heating system when boiler runs for DHW? The Vitotrol isn't a thermostat,it's a remote control.To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
viessmann question
robert,
it's a complete new install. At the moment i have to go around the house turning off each radiator individually when set to just dhw setting.
pump shows 10 and not shut off.
see attached pictures.
thanks for your advice.0 -
What country?
I've never seen an Alpha that wasn't flanged or that brand of stainless press fitting?To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Its Not What Ya Think Bob
http://www.viessmann.co.uk/en/communal_district_heating_networks/products/med/Vitocrossal_300_Typ_CM3.html
By the pic there is only a DHW call. No way to trace the problem from a pic. Could be a piping problem..That control also runs a variable speed system pump. Going to have to go through the coding and trace the problem. Could be that the control is not set to DHW Priority so no matter a domestic call of a heating call that heating pump is going to run 24/7 until you reach warm weather shut down. That boiler only has 115 degree water in it from the pic.."The bitter taste of a poor installation remains much longer than the sweet taste of the lowest price."0 -
Gotta
see how this is piped . Wider picture possible ?You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
Warranty
Isn't it a warranty issue? Where is an installer?Gennady Tsakh
Absolute Mechanical Co. Inc.0 -
Which country
robert,
I am living in Belgium. The installer has been back about 3 weeks ago but has not fixed the problem.
I am at a lose end now. Just want my expensive system working properly.0 -
Hacks
I guess it's a worldwide problem!To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Problem
I suggest that there is either a check valve(s) missing or a programming error, or both. Bring back the contractor...the system should not heat the radiators in WWSD.0 -
Viessmann question
Thanks for all the help guys, been onto viessmann and they are going to send a technician out at the request of the installer.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
