Direct venting steam boiler?
We have bought a house with steam heat and a chimney in need of repair. Is there such a thing as a steam boiler that can be vented through the wall and save us the cost of repairing the chimney?
  • jonny88
    jonny88 Member Posts: 1,139
    burnham mpo?
    I know Burnham carry a power vented steam boiler, IN PV model.its on their website
  • JStar
    JStar Member Posts: 2,752
    Power Vent
    You can also set up a separate power venter made by Tjerlund or Field Controls. It can be used on any boiler.
  • DaveinNJ
    DaveinNJ Member Posts: 3
    Great info guys, thanks!
    If either route works out I will save $6000 in chimney repair, which I'd much rather put into new equipment. Thank you!
  • JStar
    edited August 2013
    Cost
    The cost comparison will not be very fair until you know what size boiler you need, and what boilers are able to be power vented. You might find that the chimney rebuild is not so crazy of an option.
    What repairs need to be done?
  • DaveinNJ
    So true, Joe
    ...which is why I said "if"! But I'll give it a shot.
  • RJ_4
    RJ_4 Member Posts: 484
    direct vent
    I have used Tjerlund in the past,  they make a great product with excellent factory support
