first drop header
Paul S_3
Member Posts: 1,261
Believe it or not after seven years first drop header....critics welcome.....Paul S
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
347-692-4777
ASMHVACNYC.COM
Header
Sweet!
The only thing I have to say is that we avoid installing unions on the horizontal. The pipes will move around and make them leak. Otherwise, great looking job.0 -
Beautiful
Beautiful work, but I would get rid of that evil autofeeder. Either get rid of it and go 100% manual or get rid of it and install a VXT.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
thank you guys
What is a vxt..ASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Auto feeder choices
The vxt has a built in meter, but I would still keep any auto-feeder valved off, for at least a couple of months, so as to see if there is any leakage.
Auto-feeds are really the work of the devil!--nbc0 -
Automatic water-feeders
The only problem with water feeders is that, in spite of what the literature that comes with them tells you, very clearly, they make some people think they don't need to mind the water level anymore. But that's not really the fault of the water feeder, now is it? You might as well say that bad near-boiler piping is the fault of steam boilers, not the knuckleheads who can't read and follow an IOM. I guess if you really believe people are just that intrinsically stupid, then they really should avoid water feeders, steam boilers and sharp objects, but I'm a little more optimistic. I believe people can be educated, and that, armed with the right information, they can make good decisions, and I don't think hyperbole about safety devices being "the work of the devil" is conducive to that end.Just another DIYer | King of Prussia, PA
Hap
Depends, either way the only feeder I'd ever put on my system is a VXT.
Yes, it should ONLY be an emergency device and really should never turn on as the user\operator of the boiler should be manually adding. Still, I feel the VXT is a better feeder and the meter is a must. The feeder with the meter, has a good sound to it.
I still don't have an autofeeder and may never for the simple fact I can't bare to think about my boiler sitting there with fresh water in it for any length of time, emergency or not. But we all know I'm weird.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
Relief valve
Don't see one, hope it is there somewhere.0 -
relief valve
Those weren't finished pics....these are themASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
347-692-4777
ASMHVACNYC.COM
Paul
What's going on with the returns, and shouldn't they be connected below the water line?0 -
returns
they are below the waterline it just looks that way in the picturesASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
I can't bear to think about all the water spewing out of my boiler and flashing to steam
But I still have a relief valve on my boiler.Just another DIYer | King of Prussia, PA
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
