Need Help With Honeywell Relay
Big-Al_2
Member Posts: 263
The main control relay on my Burnham IN-5 boiler started buzzing loudly this weekend. I replaced it with one from the old boiler I took out last year, and it's working quietly again. I'd like to get a brand new relay, but I can't find the exact match on any of the online supply house sites and the cross-reference information I can find is confusing.
This is the bad one:
Honeywell R8222K 1000, 24V 50/60 HZ
It appears to be a simple 2-pole normally open relay with just 4 terminals . . . 2 coil terminals and 2 contact terminals . . . but maybe it has an internal resistor or something.
There seems to be a lot of general-purpose R8222 relays out there, most of them with extra terminals I won't use. For example, the R8222 D 1014 seems like it would plug right in, but the solenoid coil looks larger, perhaps higher wattage. Could somebody clue me in on what would work?
This One?
http://titaniccontrols.com/honeywell-r8222k1000-spst-relays-great-price/
Sorry, I see that's a 1014....but that's what comes back for the search.0 -
If it looks
Like the relay in Pauls first post go to a local supply house and ask for a 90-340 relay or just bring the old one in. Make sure you have the retaining wire that keeps the relay in place.0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
