FITTER
RIRED
Member Posts: 10
I would like a nice detailed drawing of the hot water heating zone off of a steam boiler including bypass loop around boiler, circ pump, switching relay, and aquastat etc. I am trying to add a baseboard heating zone to a 1st floor apartment off of burnham steam boiler. I need to determine if the boiler can handle this new heat load so I guess I need to do a heat loss calc and look at the rating on the boiler. I am in the process of doing that so any help regarding this what be greatly appreciated. Are these set ups safe?
Here are a couple of previous threads to get you started
http://www.heatinghelp.com/forum-thread/138479/Hot-water-baseboard-off-bottom-steam-heat-boiler
http://www.heatinghelp.com/forum-thread/136109/baseboard-loop-off-steam-boilerJust another DIYer | King of Prussia, PA
hot water loop
"the lost art of steam heating", available from the shop here has some good information on this.--nbc0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
