Removal and Cap of Steam Radiator
Ericfine50
Member Posts: 1
Good Morning,
My name is Eric and I am brand new here. My wife and I live in a 110 year old home in MA. We have one steam radiator (one pipe style) that we want to remove. I can disconnect it, but don't know how/what to cap the pipe from the boiler with.
Any suggestions?
Thank you
Eric
Any suggestions?
Thank you
Eric
You need to remove the valve
and cap the pipe with the corresponding size of an iron pipe cap. Why do you want to remove the radiator?Cost is what you spend , value is what you get.
cell # 413-841-6726
why remove a good radiator?
if the radiator is overheating/noisy, then the system can be restored to proper balance, following some advice from here.
naturally, the removal of the radiator will affect the rest of the system, sometimes adversely.--nbc0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
