Tankless Coil
Member Posts: 2,694
They aren't very popular out West and out of over 700 customers, I only have one that has a tankless coil in his boiler. It's a Crown G55 and I've been servicing it for about 15 years now; never a problem with his DHW until recently when the hot water will cool down when running any of the fixtures except the shower.. Any ideas for a solution.
As you might have gathered, I have no experience with a tankless coil.
Often wrong, never in doubt.
Probably the shower valve
Monitor the outlet temp of the coil with different fixtures on, and if there is a thermostatic mixing valve watch that too.
More than likely since it doesnt happen when shower is being used, the shower, especially if its a cartridge type is bypassing cold water to the hot side because of a worn cartridge. It does that because the hot side has a lower pressure due to the tankless coil pressure drop.0 -
Tankless Coil
I'll put my infrared thermometer to work and check the outlet temperature. What if the temperature fluctuates at the coil?Often wrong, never in doubt.0
- 112.9K All Categories
- 81.2K THE MAIN WALL
- 2.5K A-C, Heat Pumps & Refrigeration
- 37 Biomass
- 394 Carbon Monoxide Awareness
- 2.7K Controls
- 1.4K Domestic Hot Water
- 3.8K Gas Heating
- 101 Geothermal
- 133 Indoor-Air Quality
- 2.4K Oil Heating
- 32 Pipe Deterioration
- 583 Plumbing
- 4.3K Radiant Heating
- 334 Solar
- 12.3K Strictly Steam
- 38 Water Quality
- 12 Industry Classes
- 8 Recall Announcements
