supply damper
Paul S_3
Member Posts: 1,261
In a job in NYC there is a Honeywell damper on the supply duct directly out of the air handler...why would that be there?....it doesn't look like a fire damper but I can be wrong....it feeds a main trunk that 2 other air handlers are tied into....thank you Paul S
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
347-692-4777
ASMHVACNYC.COM
Could it possibly
be to prevent back flow through that air handler if it is off and one or two of the others are on? Or is it just on that one air handler? Dunno...Br. Jamie, osb
YUP
What Jamie said. There to close off backward flow and loss of air if that air handler is shut down - as in staging.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
