Crane heat radiators
Jay58
Member Posts: 3
We have a 1956 Crane hot water heat radiators in each room about 1 foot high that go around the outside perimeter of each room. We want to add a room addition, do they still make this style?
made... no.
found maybe. Where are you located?0 -
It's probably cast-iron baseboard
which is still available from Burnham, Governale, OCS, I believe Slant/Fin and Weil-McLain, and there may be others.All Steamed Up, Inc.
Consulting0 -
Fort Wayne, IN0 -
Crane cast iron baseboard radiators
Thank you so much! Can you recommend any distributors close to Fort Wayne, IN?0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
