CSST Mass Code
CMadatMe
Member Posts: 3,086
Can someone in Mass verify this for me. I am being told that if CSST gas piping is installed in walls that it must be sleeved. Doesn't sound right. Now it can move in the case someone did screw or nail something into it. I could also have just built myself a bomb,
as per manufactures directions.
protect where it goes through the wood. It must be able to move out of the way. As always check your code book and go by it. Since we are required to keep it in our trucks it is always close at hand for inspections. That said I only use iron,Cost is what you spend , value is what you get.
cell # 413-841-6726
Smart man...
In my humble opinion...
ME0 -
Charlie is
for sure a smart man Mark0 -
I Know
About striker plates guys. What's with the having
to sleeve? I'm not blind to the proper installation of CSST, want
to know whether Mass code requires it to be sleeved?There was an error rendering this rich post.
Sleeves:
If Massachusetts says you need to sleeve CSST in walls, it is new on me. Ask whomever said that to show you where in the code book it says that.
Bonding was a big issue but that has all been ironed out.0 -
I Have
A salesman in one of our Mass stores telling me needs sleeve material because
It is Mass code. I'm in NY and have no clue to whether it it or not. Looking
For one of you Mass guys to send me something I can send him because I
don't buy it. Been selling CSST since it was born and never heard of it. I
understand striker plates but sleeving?There was an error rendering this rich post.
CSST Mass. Code:
You need to contact the the manufacturer of the CSST and ask them.
Also, you are supposed to be able to call the Board in Boston for a code interpretation.
The Mass. Code on sleeving is found here, below. The only sleeving required is for CSST going through concrete walls andd CSST that is buried. The sleeve for undergroound must be watertight at both ends.
http://www.mass.gov/ocabr/licensee/dpl-boards/pl/regulations/rules-and-regs/248-cmr-500.html0 -
the link Ice posted is best to confirm questions at
Chris I thought you were asking as an installer. If I had the back story I would have sent you to the board link first off the bat. The code is often not interpreted well from place to place, That's why we make sure to have it in writing and on our trucks so they can show me.Cost is what you spend , value is what you get.
cell # 413-841-6726
cell # 413-841-6726
Outcome?
Chris,
What did the board say about CSST being sleeved?Bob Boan
Didn't Get There
Today, late start this morning with the snow that came in last night and caught up in catching up today. I'll get to it tomorrow. I'm just going to call Omega Flex first.There was an error rendering this rich post.
Sleeving:
The only sleeving requirement in the Massachusetts exceptions I see in that link is the ones that have always been there. If you run CSST through a concrete wall, you have to sleeve it. If you run it underground, you have to sleeve it. It also says that it must be watertight on either end.
CSST installation required installer training by the manufacturer in Massachusetts. We were all trained by the manufacturers and given cards. I have three. They gave us a installation manual. You needed special ouch plates there the tube went through shoes and plates. They had fan shaped ouch plates for nails being below a plate to deflect errant nails. I think that someone is misunderstanding the requirements.
I think that a requirement to sleeve in interior walls would be such a sea change, that it would have been ordered by The Board to include it in the CEU classes for that education cycle. In unit 2, 3 or 4, there was a big section on CSST with the PHCC courses. The Board sets the curriculum. They would have ordered it. They want every course in every cycle to be on the same page. I think we need more information based on rumor and speculation. The electrical bonding issue was a good example.
Just because someone thinks they are right, doesn't mean they are. Myself included.0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
