Weil-McLain Water Woes
AM7
Member Posts: 14
in Gas Heating
Happy Holidays all!
This is a convoluted story, but I'll try to state it clearly.
We have a W-Mc EG series gas boiler that's probably 12 years old. Until last winter it was working fine. Now, it goes through literally gallons of water in as little as a night. The glass can be nearly full at 9 pm and completely dry by 3 in the morning - at which point the house is freezing (59 degrees last night).
I had a plumber examine the piping in the basement and some of the radiators, which he tightened, but the problem continues. I also had the unit serviced in the fall.
I spoke with W-Mc and was told that the problem appears to be a cracked heat exchanger. However, the tell-tale signs of a crack don't exist -- there's no sign of water anywhere near the boiler (or in any of the walls or on the floor near the radiators, for that matter) -- and I don't see steam coming from the chimney when the unit is running.
We do get a lot of hammering, knocking and what sounds like high-speed dripping in the piping on one side of the house, but only there.
Any thoughts?
Any thoughts?
Is your condensate return line
back to the boiler buried in the floor (called a wet return)? If so it may be leaking and seeping into the ground. Your plumber should have picked up on that however.
Do you have vents on the radiators (single pipe system)?0 -
water woes reply
Thanks for your reply.
The plumber went through the basement and could find no underground pipes. If by vents you mean secondary valves (the small ones that sit on the side of the radiator opposite the main valve), then yes, that's what we have.0 -
Traps
Also check your traps to see if they have been bled, as that's a primary cause for banging.0 -
Traps
traps
Thanks. Would that have anything to do with loss of water from the system, too?0 -
Look Up!
Got clouds of white coming out of the chimney?0 -
water woes
I haven't seen any. I keep looking, too.0 -
Wet Return
Have the plumber either replace the wet return, or at least blow it out.The condensate can't get back to the boiler, and is backing up. That's your banging, as it comes in contact with live steam.0 -
wet return
Thanks for the advice. I'll ask him to take a look at it.
Could that be causing the system to run dry so quickly?0 -
Sure
Picture a pot of water boiling on high on the stove.Your boiler can produce 10 - 15 times the heat.The wet return is the garbage pit of the system. If he decides to replace the wet return, only use copper below the normal water line of the boiler. http://ezinearticles.com/?Residential-Steam-Heating-Maintenance-1-Point-0&id=31834320 -
chimney
Well, tonight I saw steam coming from the chimney for the first time. So, I guess that means a cracked heat exchanger, right?
Now the question is: do I replace the part or the boiler?0 -
Copy
and repost your original post in the STEAM section.I'd still investigate a plugged wet return. Wisps of white smoke from the chimney is normal. Clouds like an old steam engine is not. Repost to steam and get the pros take on your situation.0 -
diagnosis
Sure enough, there is a crack in the block. Now the question is: why should I accept W-Mc's offer to replace the single section when the whole unit might be faulty?0 -
Warranty
That is probably what the warranty covers.The problem is, the labor to replace the boiler section will probably be more than the labor for installing a replacement boiler.0 -
Time for a new boiler
Unless the boiler piping is textbook perfect I would install a new boiler. Replacing the section is going to cost a lot of money because there is a lot more labor involved and no guarantee that something won't fall apart in the process. Boiler warrantees keep the manufacturer honest but don't do a lot for the homeowner.
If you were going to do the labor yourself that would be one thing but time is money and your looking at a lot of hours there. Make sure a new boiler is sized right and installed right, no shortcuts!
3PSI gauge0 -
ask
Weil-McClain or the rep if they will apply a credit (for the cost of the section) to the purchase of a new boiler.0 -
Agreed
Try to get some comp from them.Just don't lock in an easy out for them. Their cost for the section is probably very small.Maybe an employee discount would be more appropriate.Try fair negotiation first....you can always settle.0 -
Be Careful How You Bark
They may just ask for you to send the section back for inspection. What section and where was the crack at? Just because it's cracked doesn't mean it's defective. If the cause goes un diagnosed you'll have the same issue down the line. Here's a little article fo digest before you bark too loud.
http://www.heatinghelp.com/article/323/Boilers/244/Steam-Boiler-Failure"The bitter taste of a poor installation remains much longer than the sweet taste of the lowest price."0 -
Please...No Barking!
I definately wasn't advocating that. If you become the enemy of the person on the other end of the line....YOU'RE DONE. Be kind and ask for their help. They may be able to offer you something good.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
