Peerless ect 06 2.75
Just Done some work at this building
Gorton number 2 Main Vents, change radiator valves, Hoffman 40 radiator vents.
Question boiler has a 2 inch header installation manual calls for a 3 inch
When I suggested changing homeowner wants to know what benefits could Be seen from doing this
Looking for some suggestions thanks in advance guys
  • More space
    I'd say there are at least two reasons for an oversized header.  One, it slows down the steam so that any water carried along from the riser can drop out in the header and two, it provides more room for the water on the bottom of the pipe to keep separated from the steam at the top of the pipe.
  • Steve_210
    Steve_210 Member Posts: 650
    Thank you Alan
    Problem is it does not seem to be causing any problems right now
    I guess my real question is will it improve efficiency anything
    Quite a bit of work involved and I don't want to put him to Any unnecessary expense
    The Larger Header would definitely purchase dryer steam
  • Steve_210
    edited December 2012
  • Benefits from following instructions
    Maybe this is not the time to cut out the old shrunken header.
    You could ask them to listen for wet-stem rattles in the radiators this winter, and then perhaps they will agree to have it changed in the spring.
    My guess is only a 5% difference in efficiency of fuel use, but maybe 10% in comfort.--NBC
  • Steve_210
    Thanks Nicholas
    Since posting one of 6 Tenants have complained of a radiator Spitting
    Makes you wonder how many are not Complaining
    Once they have Heat, What do they care.
    We are repiping the boiler within the next week thanks again
    Steamhead Member Posts: 18,170
    Be sure
    to take plenty of before and after pictures and post them!
    Consulting
  • Steve_210
    Will do
    Thanks again
