Drill and tap for 3/4" pipe.
RICK_64
RICK_64 Member Posts: 20
The main vent on my one pipe/steam system was originally drilled and tapped for
1/2" and uses a 3/4 to 1/2" adapter to accomodate a Gorton vent (possibly a #6 or a
"D" size...). I'm looking to install a Gorton #2 which will require me to open the hole up
to 3/4". Can some one tell me the correct drill bit and tap size needed to do this?
Thanks to all the pros on this site for their insight and info.
    Steamhead Member Posts: 17,932
    The Gorton #2
    has 1/2" male thread- so you don't need a 3/4" hole.
    Consulting
