Halloween install
gennady
Member Posts: 839
Wow!
I first got dizzy looking at it and then started to get a headache. Please say it's a D.I.Y job.0 -
No, it is not
No, it is not DIY job. Done by master plumber. Cost 30K.
I was called in because homeowner has to push reset button once in a while. Other than that no complaints.Gennady Tsakh
Absolute Mechanical Co. Inc.0 -
Plan?
The plan evolved with every fitting! At least they left you an empty bucket to put all the crap in.0 -
plan
I will not take a part in this mess. After checking DOB website, found plumber did not closed job and permit is still active.Gennady Tsakh
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
