peerless steam boiler equalizer.
sal_8
Member Posts: 2
piping in a peerless 177000.btu steam boiler i see inch and a half min for equalizer. any problem just comming down full 2 inch into a 2 inch tee.
None that I know of.
You can always go bigger, within reason, and it's fairly common to keep the same diameter as the header down to the water line.Just another DIYer | King of Prussia, PA
1983(?) Peerless G-561-W-S | 3" drop header, CG400-1090, VXT-240
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
