Gifford Loop ?
RAF
Member Posts: 65
Wondering if anyone has used the Gifford loop and how it's working out?
old post, new reply
I know this post is really old, but I installed a Gifford on my system and it has worked great. I've had no hammer, even with other parts of the system being messed up.0 -
JPF321
JPF321, a poster who has not been around for a while installed a new boiler a year or so ago. He used a Gifford loop. As I recall, he was quite happy with it. You can find some of his posts. He has links in his signature line to many photos of his installation.Dave in Quad Cities, America
http://grandviewdavenport.com0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
