No vent system
Bio
Member Posts: 278
My nephew just closed on a house and ask me to check his boiler, well I don't see a vent set up, it looks like someone in the past used it as a possible take off, but when I tried to follow the take off It could not be found on the first floor either as a radiator or as a vent it looks like it's in between walls upstairs, space is minimal to work, right at the corner is a reducing tee 2x2x11/4, pipe goes down to almost floor level then runs to the boiler for about 30', Where do you guys suggest we can set up a new vent and yes near boiler piping is terrible
I hope pictures will be attached
Venting
If it's too much trouble to cut into the main, I will sometimes add a tee righ after the elbow that drops into the return. A few feet of the smaller size pipe is easier to work with, and less expensive than dismantling the main.0 -
You can drill and tap
right into the 2" pipe. I never go above 1/2" on something as small as a 2" pipe, but with a low setting for the pressure and a good thread in the pipe you should be fine.Cost is what you spend , value is what you get.
cell # 413-841-6726
Vent setting
Thanks, so I will drill & tap from the top about 15" away from the drip elbow and attached a gorton 2 (50' main length), am I on the right track?0 -
That should work
and you'll love the difference it makes!All Steamed Up, Inc.
Consulting0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
