Radiant layout
Jim Pompetti
Member Posts: 552
What would be the amount of tube that can be laid a day. Its a warehouse area not any upstructions.
Jim......
What size tubing & how are you fastening it? Staple up w/without plates, staple down for wet bed, subray, warmboard, tying to wire mesh?steve0 -
radiant
18 ins on center , tying to wire mesh0 -
It depends upon the method used...
If you will be tying by hand, you can figure about an hour to an hour and a half per 250 foot loop.
If you spend the money for a nice rebar tying tool, the time falls back significantly to about an hour per loop.
It also depends upon the person doing the work. You or I will probably take a lot longer than the young Jamie would take... We don't get up and down as easy as we used to...
MEIt's not so much a case of "You got what you paid for", as it is a matter of "You DIDN'T get what you DIDN'T pay for, and you're NOT going to get what you thought you were in the way of comfort". Borrowed from Heatboy.0 -
tracking
I like tracking and have been using it exclusively for the past 10 years, I can lay a 250-300ft loop in a 1/2 hour average. Tying to rebar or mesh really sucks. ;P0 -
ME
If I was tying it ,I'm sure it would be 1 1/2 days per loop0 -
Alot
Use the radiant matts and you can drop alot of tubing in a day.
http://www.uponorpro.com/Extranet%20Home/Products%20and%20Applications/Products/Overview.aspx"The bitter taste of a poor installation remains much longer than the sweet taste of the lowest price."0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
