Radiant layout
Jim Pompetti
Member Posts: 552
What would be the amount of tube that can be laid a day. Its a warehouse area not any upstructions.
Jim......
What size tubing & how are you fastening it? Staple up w/without plates, staple down for wet bed, subray, warmboard, tying to wire mesh?There was an error rendering this rich post.
radiant
18 ins on center , tying to wire mesh0 -
It depends upon the method used...
If you will be tying by hand, you can figure about an hour to an hour and a half per 250 foot loop.
If you spend the money for a nice rebar tying tool, the time falls back significantly to about an hour per loop.
It also depends upon the person doing the work. You or I will probably take a lot longer than the young Jamie would take... We don't get up and down as easy as we used to...
METhere was an error rendering this rich post.
tracking
I like tracking and have been using it exclusively for the past 10 years, I can lay a 250-300ft loop in a 1/2 hour average. Tying to rebar or mesh really sucks. ;P0 -
ME
If I was tying it ,I'm sure it would be 1 1/2 days per loop0 -
Alot
Use the radiant matts and you can drop alot of tubing in a day.
http://www.uponorpro.com/Extranet%20Home/Products%20and%20Applications/Products/Overview.aspxThere was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
