Dunkirk Helix VLT Vertical Laser Tube condensing boiler
Midrink
Member Posts: 5
All set - Thank you
dunkirk complaints?
what were the complaints about, in regard to that boiler? a lot of people don't realise how important the installer is on a replacement, and so maybe the problems had more to do with that rather than the boiler itself.
many home owners also are surprised at the amount of time required for a yearly maintenance on all condensing boilers, and so complain about that expense.
why not post details of your situation, and everyone can voice an opinion as to what choice of boiler would be best for you.--nbc0 -
Dunkirk Helix VLT Complaints
All set0 -
searching the wall
if you do a search here, any postings having to do with that particular boiler will come up.
however, read between the lines as to whether the problem might have been "knucklehead-generated". the real pros will simply remark on ease of service, manufacturing defects, or difficulty with spare parts, etc.--nbc0 -
Midrink
It's like asking a Ford dealer what he thinks of GM. Of course, that supply house would recommend boilers they sell. Saying that a mod/con is sensitive to scale and sediment, is like saying a redheaded Irishman is sensitive to the sun.....No Kidding! The difference is that it is designed to resist that.0 -
Helix VLT Boiler
Good Points.....Thank You!0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
