Bubbles in water glass
STEAM DOCTOR
Member Posts: 1,973
Good eve. I was on a job today. When firing boiler I noticed bubbles rising in the water glass. The bubbles stayed on top of glass for a good few minutes without breaking up. I am assuming that those were steam bubbles and they were trapped by oil on top of the glass. I don't recall seeing anything similar in past. The water was moving up and down more then it should but not nearly as bad as many that I have seen. Any insight would be greatly appreciated.
Blowing out the bubbles
You could always install a small ball-valve on the bottom gauge-cock, and blow out any oil which may have accumulated. Following that you could see how long it took for the bubble phenomenon to reappear.--nbc0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
