Fan over speed pl 199 boiler
drewel
drewel Member Posts: 2
Every 7 or 8 cycles get the F14 error mesage checked wires  it went away for 2 weeks than started to happen again. fan speed 5900 at pre burn and 3600 durning burn. how do I tell wheather rto change fan or control ?
  • Tim McElwain
    Tim McElwain Member Posts: 4,612
    Sorry PL 199
    does not tell me who makes the boiler, need that info to be able to help you.
  • Jr_12
    Jr_12 Member Posts: 38
    Pinnacle
    Sounds about right...most likely a bad Blower motor, but kind of a crap shoot
  • Paul48
    Paul48 Member Posts: 4,469
    edited February 2012
    Corrective Measures
    1. Check the combustion air fan wiring.
    2. Replace the combustion air fan.
    3. Replace the control board.
    I doubt the control board could be checked properly in the field.
  • Tim McElwain
    If it is a Peerless
    Pinnacle I believe it has the same board as a HTP Munchkin. I have the procedure for checking the board in my Mod/Con Manual Volume I, it covers the original Honeywell board (1996) the and the two later boards (925 & 926) the HTP products used.
