Wirsbo manifold adjustment/temp differential
wrxz24
Member Posts: 301
Just curious about the little back disc that controls the flow on the
older cooper wirsbo manifolds 7 outlet with the black caps. I saw a
post on the Main Wall about someone who said to adjust all of the black
disc so that it is about a dimes thickness above the brass collar. Mine
discs were level or slightly below and there was about a 14 degree
temperature differential (90 vs 76 )between each of supply and return
loops. Temperature was 4 degrees.
My question is this. Is there a recommended temp difference between the
supply and return loops after the system has been up and running?
Thanks in advance.
Thanks in advance.
temp differential
ME was gracious enough to message me info on temp changes with the 7-10 degree differential with the system up and running. I now have 90 degree water going out and 83 degree water coming in.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
