Burnham alpine boiler
dejew
Member Posts: 1
in Gas Heating
I have a Burnham Alpine boiler that is setting error 29, I can reset the controller and it may run 1- 10 cycles before it resets. The fan is not shutting down all the way, I just want to make sure it is the fan or is there another problem
E 29 Code
E 29: Blower fan speed has not returned to zero rpm
• Miswired fan speed harness
• Defective fanBob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
