header
steve_25
Member Posts: 36
i have a 5 inch header exsisting.new boiler has two outlets.do i build another header and feed the big header?i do not want to remove old header.
pics please
pictures and more information would be a big help. What type of boiler are you going to install?
Yes, it is possible to build a new header and equalizer for the boiler and then connect a supply line to the old header.
However, it is impossible to say if this is a good idea without more information on your system and your proposed boiler.Dave in Quad Cities, America
http://grandviewdavenport.com0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
