Anyone Know What This Valve Is?
Dan24
Member Posts: 1
Hi,
I recently tapped into my supply and return pipes for the installation of a infloor radiant system. I currently have cast iron radiators (hot water) supplied by a Burnham Oil fired burner. After tapping into the pipes a valve ontop of my supply pipe started leaking. It looks very correded and I think the flanges will need to be replaced. I have searched part numbers and come up with nothing. On one side of the valve it says "Trane Flo-Valve" and on the other side there is a selector switch that says "normal" and "open" it is currently set to normal. The part number on the main valve is 1131 and the flanges are 1118 and 1116. Does anyone know what this is or where to get one? Thank you in advance for your help.
Re: what valve is that
That is a gravity flow control valve to keep hot water from gravitating up main heat pipe when pump not on.0 -
WIRE?
IF IT IS A FLOW CONTROL VALVE WHATS THE WIRE COMMING OFF THE TOP0 -
flo valve
i have the same problem where can i purchase a new gravity flow valve HELP!
flo valve
The wire?
There's no wire coming out of it....it an optical confusion....looks like its going into the junction box on the wall.
For that flow control valve, you're better off bringing in a pro. That's not a trip to home depot. You're going to have to get that from a large plumbing supply house. You're going to have to drain part or all of the system, and we all know what can, and usually happens next. All those valves you open and shut to drain/fill start leaking, need to be fixed/replaced, etc. So get someone who's going to have all the parts to get it down in a few hours.steve0 -
The good stuff
Yup Flo control valve. Open position allows gravity to commence if there is a power outage. Provided of course your boiler does not require power. I would not throw the baby out with the bath water. Gaskets, and pipe dope may save the day. Clean up on the flanges for sure.
Gordy0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
