steam heat help radiator valve leaking A LOT
katg
Member Posts: 4
I have steam heat. One of my radiators is leaking widly from the valve. I've turned off everything! Still been leaking for 6hours. Can't get to the plumber until the morning. I thought the water would leak out and that would be the end of it until I could get someone here. It's been hours..and gallons! I fill a 10 oz glass every 7 minutes. help
Big leak
Have you access to the boiler?
I suspect the auto/overfill system is constantly filling the system with water. There should be a valve to shut off the flow of water into the boiler. Turning off the power to the boiler should also prevent the valve from feeding the boiler. Let us know of any other observations.--NBC0 -
checking
checking be back!0 -
Had the same problem
In a different life.
There may be a circuit breaker which will kill the power to the boiler and auto/over-fill.--nbc0 -
all turned off
all turned off both by power. Still leaking...I will wait a while longer..putting down mucho towels..will check in a few hours...so nervous!0 -
ok
ok tks!0 -
Valve
Now that you have turned off the power, were you able to find a water valve to turn off?--nbc0 -
Leaking dhow or auto-fill
Can you turn off the water for the whole house, as you may also have a hot water coil on your boiler which would not be affected by turninig off the auto fill?
If he does a lot of work on the boiler with new parts, make sure the boiler is cleaned (see skimming)__nbc0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
