consumer
GCEMM
Member Posts: 1
in Gas Heating
My plumber is suggesting i get a burnham cast iron gas boiler with direct vent SCGTM series but he said i need a converter to convert the boiler from natural gas to propane gas. We are using propane. I did a search and it seems that burnham has propane gas boilers for a hot water heating system. Do all burnham gas furnaces have to have a converter for propane? Does this ruduce the efficiency of the system? Thanks
It often depnds on
manufacturers and how they set up their equipment.
If a boiler or furnace is purchased set up for natural gas with the option to convert to propane then a kit is made available and can be installed by a professional technician. It should then be tuned to the new fuel and a combustion analysis accomplished.
The propane actually burns with a hotter flame than natural gas so there is somewhat of a little better BTU available. Equipment typically works fine on either fuels because both are brought to the burning process as vaporised fuels.0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
