Please help me turn off my radiator. Thank you!!
Jason222
Member Posts: 1
Hi,
I'm attaching some photos of my radiator. I can't figure out what might be the valve to turn down the hot water. It is getting very toasty in my room, even with the windows open! Any help is much appreciated. Thanks so much!
Jason
Jason
toasty room
this appears to be a hot water system. there is a valve on the end which may work, but i suspect the cause is more system-wide, such as a thermostat located in the wrong place [or the wrong thermostat located in the right place]. if this is an apartment, then can you report this to some maintenance person?
has this been a problem before, or is it a new occurrence? something must have changed, and it is wasting energy.--nbc0 -
while not a perfect fix
You can take a crescent wrench to the valve end, ( where it is shaped like a square) and tighten down on that to turn it. However if its hot water, I don't know if you can throttle it, I own a 2 pipe steam sys. so that's all I worried about. If it is indeed a steam system, then it's 2 pipe so you can turn down the supply. If you don't have a crescent wrench, the replacement valve handles are a very inexpensive purchase at many local supply houses.steam newbie0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
