mod/con with indirect or on demand water heater
radmix
Member Posts: 194
Which is more efficient a Mod/Con With a side arm or a on demand water heater. My guess is the water heater with the condensing boiler.
A well insulated...
Indirect would be my choice. The combustion Eff. numbers will also be a bit higher w/ the mod/con. Furthermore I am not a huge fan of having a boiler sit idle in the non heating season. kpc0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
